I bought a book on sailboat electrics. There is a section on having the electrical system's ground ran to the engine, that in turn is connected to the prop shaft and into the water.
I have a rubber coupler in between the engine output and the prop shaft. I assume it isolates the engine from the prop shaft electrically, but I haven't tested it yet.
The book says you can have the prop isolated from the engine but then there must be another ground to the sea.
Is it ok to use the keel for the ground? Is there a special type of through hull that is just for this purpose?
Do you guys run your ground through the prop or another path?
I have decided to leave my boat on the hard for the winter like the yankees do. I am going to replace the through hulls and check out the rudder. It seems like a lot of rudders fall off at the worst possible moment.
