I've learned a lot about DC electrical systems since buying my boat a few years ago but I'm still not clear on something. My system is 12 volt and I'm installing a pump that draws 20 amps. The wire from my distribution panel to the pump is 10 ft. long. This means that the length of the circuit is 20 ft. (10' there and 10' back). I get out my little wire sizing chart and determine that, if a 10% voltage drop is acceptable to me, using 14 AWG wire would get me about an 8.7% voltage drop. Since I have a large spool of 12 AWG wire, and since maybe someday this pump will go bad and I'll end up with one that draws a little more, I'm going to use the 12 AWG wire, which should give me a voltage drop of about 5.5%. My question is, with all this information, how do I determine what size breaker (or fuse) to use?
