Electrical troubles
Restful-mind
Help! I need an electrical schematic fot Hunter 26.5 1988. Problems with Running lights and fresh water pump. Accept all suggestions.
Alan
Jun 2, 2004
4,174
Hunter 35.5 LI, NY
To start your trouble shooting, is the entire circuit dead or just certain lights? Start by checking for current on both sides of the circuit breaker/fuse. If parts of the circuit are working check back to the last connection and work forward from there. It really isn't rocket science but just a matter of tracking down the probable faulty connection.
GuyT
May 8, 2007
406
Hunter 34 South Amboy, NJ
If there are breakers for each of these loads,
you just need to measure voltages at both points. Many, Many times the problems are from corrosion. Get out a voltmeter and see if you have voltages at the loads. Should be simple to trace it back if you dont.
A
alikolbe
problem too
We are also having a problem with the electrical on our 23.5, nothing is working, I am wondering if the masthead electrical socket has to be plugged in, to complete the circuit? Not sure , this boat is new to us. Thanks
