Mac 25 Wiring
I accepted when I bought my Mac 25 a couple of months ago that I might have to do "some" wiring. I accepted that would likely be the reality with any boat I would have bought.Upon getting it home and hooking up the battery, I discovered I had cabin lights and that was it. The stock three switch panel in mine had breakers instead of fuses and the breaker on the nav lights wasn't working and seems to be toast. The PO had also added a car stereo in the cabin, a switch for DC or AC power for the omni-directional antenna that came with it, a depth finder had been hard-wired and it looked like a few other things had been hooked up and removed over the years using overlay splices (I don't know whet else to call the splices that clamp on to a wire in the middle). There were also several different un-marked wires that led to the battery.The end result is an electrical system that looks like spaghetti with a mis-wired stereo and depth finder. My next purchase now that the weather is cooling off and I can stand to be in the cabin for awhile is to overhaul the electrical.Here's what I'm planning- only two wires to the battery, probably 10 ga. run to a battery master switch for the eventuality of using two batteries. From there bring a pos and neg into a new West Marine six switch panel. Circuits will be: bow and stern lights; mast light; cabin lights; stereo; GPS & Depthfinder; auxilliary outlets (cigarette lighter receptacles- I have one mounted forward and another by the companionway). I'm going to leave the bilge on it's own switch as it is now. I've got an automatic pump with manual over-ride. That will wire to the mains from the battery on the battery side of the battery main switch for obvious reasons since I leave the boat in the water.The existing wiring to the lights appears to be fine, I'll test for shorts and resistance first though. In order to accomodate the circuits where I have multiple lights or functions, I'll use bus bars so I don't have to piggy-back splice anything and trouble-shooting, IMO, will be easier down the road.I will also likely add a solar battery tender at some point in the future. For now, I've got shore power and can charge the battery sufficiently. I'll likely also add a volt meter between the battery switch and the distribution panel.DC is easy to wire.
