Mike Linstrom
Survey said battery 2 was weak so I moved battery 1 to the 2 spot and put a new battery in the 1 spot. Boat has a charger and is hooked to shore power. I turned on AC main, DC main, and turned battery switch to "both". All other switches on the electrical panels are turned off. Shore power works because AC outlets work. After a week the indicator on the electrical panel shows the charge at 50% and much lower when I switch to battery 2. What's going on here? Could the charger not be turned on? There"s no switch for it on the electrical panel.
