My 1989 O'Day 322's 2GMF Yanmar engine starter has an electrical problem. When pushing the starter button electricity seems to be draining off rather than going to the starter. The starter will eventually begin to turn the engine over and fire up. I can smell burning, like wire insulation, and there is some grey smoke in the battery compartment. The 10g negative wire (which is grounded to a heavy metal drain pipe) is warm to the touch but I can't identify the source of the smoke or smell. I have two new heavy starting batteries as #1 and #2. They in turn are connected to a third large deep cycle battery so there is more than enough current to easily turn over the engine. I have owned my boat since 1989 when it was new and the battery arrangement has remained the same. This problem began about two years ago. I remove a previous lighter ground wire last year which got so hot that it burned off the insulation. That's when I replaced it with a heavier wire. I know enough to realize that the problem is related to the heated wire (duh) but that's about as far as my electrical knowlege gets me.Any ideas or suggestions?Al
