Mike Whalen
Just got out of trying a murder case next week so I might have time to tackle that eletrical mess. I have a 25 O'day with what looks like a standard panel with labeled switches. I haven't seen the back of the thing and I got an idea it won't be easy to get to. What I expect to find are wires running from that panel directly to the terminal on the battery (there are several of them attached there). In the West catalogue I see a couple of bus bars. One has 20 screws and the two terminal posts. I've done some home wiring (and one converted school bus wired for 110) Are these twenty actuall ten pairs with a hot and a ground? I suppose that I'm gonna run one wire from each battery post to the bus bar then run from the panel to the bus bar. Surely I'm not running the individual grounds to the ground post on the bus bar, am I? None of the other electrical projects I've done have blown up or burned down YET. I suspect I can pull this off. Any suggestions. WHat I have are: (1) running lights, (2)VHF
