Stu, Dave, and Donaflex...
Stu, we're talking about a Raymarine S1 autopilot here. Those are quotes from the SmartPilot Series Commissioning Guide dated Sep 2006--mine says the same thing. It does not mention a keel specifically; the exact cautionary notation reads "S1 system MUST be connected to ships ground." They supply a 1/4" tab female crimp-on for this (yellow barrel = 10-12 AWG wire) to make this connection to the computer board's lug.
They call the wire the "earth strap" and say it should be connected to metal that is in contact with the water (now THAT says "keel" to me). They add that if that's not possible, it can be connected to the negative pole of the battery "(ideally at the battery itself)". Lastly they caution to keep the earth strap as short as possible.
Given the distance from where I intend to mount the computer, it's about 10 feet to the nearest keel bolt and less than 4 feet to a battery negative post, hence a 10AWG wire to the battery is in order.
Dave: thanks for the update regarding X-5. There must be some differences between it and the S-1. Bill Roosa may have touched on that--possibly a change in componentry. All the surface mountings tell me that there are a lot of components that may have been fried with conventional solder heat application instead of wave soldering.
A comparison to the ground plane for an SSB radio was mentioned. I suspect that an SSB radio's grounding need is significantly different than for this autopilot.
Donaflex: the case is molded plastic, with no likely electronic field impact. The unit has a separate, dedicated plus/minus power source connection. There is a cautionary note also about interferring with other electonic components, causing things to "function incorrectly". Raymarine also supplies "suppression ferrites" to be used with non-supplied cables, placed nearest the Raymarine device.
