Electrical outlets replacements
Mar 26, 2011
3,837
Corsair F-24 MK I Deale, MD
The reason for the advise to use all GFIs is that the lead GFI only protects the circuit properly if they are chained properly. Since you can't see the wiring, many suggest simply using all GFIs.
BobM
Jun 10, 2004
3,269
S2 9.2A Winthrop, MA
In my experience you shouldn't use multiple GFIs in a chain because they fight and wont work correctly. I installed two, one on either side of my kitchen sink as i didn't realize they were on the same circuit and it didn't work. As i recall the upstream one kept tripping. Another piece of advice is that they should be tested and changed as necessary or sooner in a marine environment.
BobM
Jun 10, 2004
3,269
240v on a boat. That is pretty scary stuff, although i love 240v clothing irons when i travel on business.
Mar 26, 2011
3,837
In my experience you shouldn't use multiple GFIs in a chain because they fight and wont work correctly. I installed two, one on either side of my kitchen sink as i didn't realize they were on the same circuit and it didn't work....
I have not had that expereince; my prior boat had several chained, and I have pluged GFI multi-strips into GFIs without difficulty. But I can see it. In truth, the best answer is always to KNOW what the wires do.
