First of all, I solved (with help from you all) the earlier problem with the boat electrics (a bad ground connection). Many thanks to you all, this is the very best of what the Web is all about.Here's the next mystery. While crawling around the wiring for the Yanmar 1GM10 engine on my 1981 Hunter 27, I came upon this female jack for a two or three blade-type plug (it's the white plastic one-a little out of focus,sorry-sticking up in the center of the photo next to the air filter intake)just aft of the starter. The three wires going into the jack join the bundle that goes to the two plugs that connect the wiring to the cockpit instrument panel (in background). The jack is on a short wire (3-4"), suggesting that it plugs in locally or that the mating plug is on a longer wore. But I cannot find ANYTHING that looks like it should plug into this jack and I spent almost an hour-with a flashlight-looking). I can't find anything that corresponds to it in my Yanmar manual (it's not a connection to the oil pressure or water temp sensors-I've located those). Everything seems to work just fine otherwise, but it's driving. me. mad. Or is it just decorative?Any ideas? What plugs into this? (and let's keep it clean
