RichJ
I own a 27' O'Day, I have been thinking of adding shore power (30A) to her, and have a couple of questions.I know about the boatside inlet, the outlets and wire I am supposed to use, my question is about the AC breaker panel. I would like to run 1 or 2 outlets and an electric / alchol stove, do I need to use a 30A dbl pole main breaker and a breaker for each line? can I just use a 3 breaker panel with out the main? or do I use the 30A main without the individual breakers and run the whole system from jbox to jbox?I tried to look up the ABYC standards, but in 2hrs of reading them I'm totally confused.also, whats up with "marine" stereos?, I understand the need for speakers with a low magnetic field, but couldnt you use a automotive stero unit? seeing that the unit would be mounted inside a cabin well away from the elements, I would think that a automotive stereo would sufice.your thoughts (as always) are appreciatedRichJ
