N
Nice N Easy
Before heading south from Ct. last month, decided we needed some form of refigeration on board. So, bought an office size frig, an inverter and two 105AH deep cycle batteries. Older house battery was a single and fairly old. The inverter is a 2000 Watt, inverter/charger. All installed and working as it should far as I can tell. Not the problem. Can not keep the house bank up with the frig on for an entire night. Batteries are just too far gone to run the fridge all night. When the batteries are charged up, either from the alternator, or the charger, they show the proper voltage. Between 12 1/2 and 13 volts. This is on the on board voltmeter, and with a digital. A hydrometer shows one battery to have one two bad cells, and the other to be about half charged. I have disconnected and tried each seperately. Still the exact same readings. Either one by itself will run things for approx. three hours before it is too low to kick the inverter on. The fridge, according to the info plate, draws 0.95 amps at 110V. By my way of eyeballing numbers, it should draw approx 10 amps at 12 volts. With a 50% run rate, this thing should still run all night on a single battery. I have the exact same setup on my boat, and it will easily run everything for 24 to 36 hours and still have enough left in the batteries to crank the engine. The only thing I am sure of is that something is wrong. Any ideas out there. I know there are some really sharp people on this board, so any answers, ideas or suggestions would be greatly appreciated.ThanksPhil Prater
