So for a couple of weeks the Quest sailboat has been experiencing electrical problems and I have commented in other threads about my progress. Since it is unfortunately ongoing, I am going to consolidate everything and post progress here.
To catch up somewhat...
About three or four weeks ago (just prior to when TS Karen came loitering along the Gulf Coast) everything was hunky dory. When resetting after the storm that wasn't, hitting the starter gave a clicking solenoid but nothing else. Batteries (at first) appeared to be charged, so I assumed that the solenoid was kaput. After replacing it and still having the same problem, I needed to step back and tackle this methodically. Batteries may not have been properly charged after all.
Specific gravity tested good in three of the four 6v golf cart batteries. 4th one showed slightly below the green zone on sp gravity tester.
Resting voltage at 12.5v on bank one, and 10.5v on bank two. One of the gc batteries on bank two is showing low charge. Same one with lower sp gravity.
Hitting the start button immediately drops voltage from 12.5v to a fluctuating low voltage like 4v.
1. Charger does not seem to be charging the batteries. Alternator too is not outputting charging voltage , though possibly not related.
So I have this evening isolated the batteries from everything but the charger and they are now showing a better charging voltage level of 14.x volts instead of 12.5 volts. Supports the theory that I have a short somewhere draining my batteries.
Hoping that by tomorrow afternoon the batteries will have recovered enough to actuate the starter. Currently used my car battery hooked directly to the solenoid and started without issue.
2. If batteries recovered tomorrow, then attempt to start first by existing wiring and then by bypassing wiring with jumper cables. That would suggest a short too.
Then continue to try to find any short by tracing wiring back from the batteries.
3. If batteries not recovered then try a remote heavy duty charger to help out charging.
4. If batteries still not charging then take then to get tested and possibly replaced.
Must Resolve the battery issue before tackling any possible shorts.
Stay tuned for more.
JQ
JQ
