Electrical Fault
96
Catalina 309 Sydney
Hi all
Went for a sail last night
The first thing I noticed was that my engine battery was down to 11.5 volts, it was ok last week and never has problems keeping a charge
The AGM battery is about 1 year old
Got the engine started and now find a few things not working:
Rev counter
Fuel gauge
Wind instruments
Auto pilot
Nav lights
Had a quick check of fuses and battery terminals but couldn't find a problem
I'm going back tomorrow for a closer inspection, any ideas or experience on this topic
Thanks for any feed back
Steve
Pompadi
Feb 6, 1998
11,772
Hi all
Rev counter
Fuel gauge
Wind instruments
Auto pilot
Nav lights
Steve
Pompadi
Those are all rather random unassociated items.....Lightning...? Is the alternator charging with the engine running? Does your shore battery charger work?
Apr 3, 2012
96
Catalina 309 Sydney
Battery charges again with 2 hours of engine
We're Not connected to shore power
I'm thinking earth fault
Or maybe a short in engine control panel
The nav lights seem unrelated but maybe a common earth for those
Had a storm the other night maybe that's caused the problem
Aug 2, 2009
651
Catalina 315 Muskegon
Huh. Peculiar.
The only thing I see in common is all the problems are with things located on the steering pedestal. Including the nav lights, because when you turn on the nav lights, normally the instruments on the engine panel (on pedestal) light up.
Mar 20, 2007
500
Catalina 355 Kilmarnock, VA
Siamese said:
Huh. Peculiar.
Mine must be wired differently. My instrument lights are lit any time the engine is running, and are independent of the nav lights. Suspicious for a lightning strike near enough to cause random electrical malfunctions.
Apr 3, 2012
96
Catalina 309 Sydney
The lights on all the instruments are still working
Tacho and fuel lights come on with ignition key switch
Apr 3, 2012
96
Catalina 309 Sydney
The latest
Nav lights both blown
Battery service light blown
Engine battery not holding charge
Wind speed not working and auto pilot has seatalk failure message
Rev counter and fuel gauge not working
Apart from that life is good !!
pk104
Jun 30, 2009
208
Catalina 310 Atwood Lake
Ten years ago I had the same thing happen on a 30 Catalina but I knew it was lightening because I was on the boat anchored at night and saw the reflection in the water when it hit the antenna on top the mast. Took out most of the same things including the frig. Interesting enough not one fuse blew.
Have you checked the boat for leaks? I never found an exit point on my boat that went through the haul but when a friends boat got hit it was leaking bad enough we had to get it out of the water the next morning.
Apr 3, 2012
96
Catalina 309 Sydney
No holes in the boat, hadn't even thought about that !
Marine electrician had a look yesterday and has put it down to lightning
Battery problem was being caused by the stereo which was draining 1.6 amps
Seems that the stereo gets its stand by power from the engine Battery, bit of a strange set up.
Big question now is the insurance, I'm sure they will behave in their typical manner ...!!
