Or maybe it is just a challenge for me...I have two perplexing symptoms that do not seem quite right, maybe related, maybe not.In reinstalling my batteries for the upcoming season, I began with my starting battery, (much easier to get up the ladder on the hard) and hooked up the 1+ & 1- cables as marked from last season. While replacing my holding tank (another story completely) the only way to get power to the DC panel was to have the selector switch on both. Once Inspiration and Play was in the water yestarday I installed the house bank (2 6volt) and hooked them up to the 2+ & 2- cables. I disconected the starting battery and had the same problem (no power at 2 or 1, power on both) Then I reattached the sarting battery and I now have power at 1, both, 2. I have tried switching the positive cables and no change. Then while leaving the boat all power off with the selector in the 2 position I was watching the Heart battery monitor bounce betweem -.3 amps & +.7 amps. My batteries must be connected and stabalizing. I figure I have a bad selector switch. Maybe, I have not traced the cables to assure proper installation, that will be today. Or do I have a bad combiner, (Which doesn't take in to account the single battery install issue)My electrical system includes a negative bus bar, battery combiner, single 4 position selector switch, Heart 10 battery monitor for the house bank, 2 6 volt house battery bank and 1 group 27 sealed starting battery.I have searched the archives, refered to Sailboat electrics simplified by Don Casey, and Manageing 12 volts by Harold Barre no clue from these sources. Maybe it is very simple and I just can't see it I do not want to start replacing pieces without having an idea of what is going on. Thanks for your help.
