Electric Winch
kair58
Nov 26, 2012
7
Beneteau Oceanis 373 Houston
I am replacing my standard Lewmar ST30 winch to a electric ST40 EVO. Rather than tie in to my house battery, i intend on adding a separate battery to power the winch motor. Since the winch is not used all the time, I plan on installing an inverter on this battery for charging electronics, ipad, iphone, etc...
I am looking for any pros or cons on this idea. My intent is not to draw down on the house battery for charging non essentials.
Thanks.
Beneteau 323 Annapolis MD
... I plan on installing an inverter on this battery for charging electronics, ipad, iphone, etc... I am looking for any pros or cons on this idea. My intent is not to draw down on the house battery for charging non essentials.
Why not just get the approriate 12 to (?) converter(s)? Lots cheaper than inverters and the wiring. Inverters waste electricty. No mater the source, you're drawing down SOME battery that has to be recharged. AND, what would you do if your "winch" battery is drawn down- or just dies? :eek:
Gunni
Mar 16, 2010
5,937
I am in the process of removing my inverter. There are no electronic devices that will not recharge quicker, and more efficiently via 12 vdc. And just like the added complexity (and draw) of an inverter, a separate house battery for a winch would not be my choice. Those things can draw 50+ amp hours/day requiring at least a 110 Ah battery. Just plus up the house battery, and spend the savings on solar charging.
kair58
Nov 26, 2012
7
Thanks Gunni & Ron20324. So inverter is not recommended, direct 12 vdc converter is the way to go. Gunni, when you mean "plus up" house battery, are you thinking increase the battery Ah? I already have 2 size D house batteries.
Gunni
Mar 16, 2010
5,937
If those batteries are 4D then you have a nominal 200 Ah to play with. And that is a good size for a 37' boat, and I can't see putting more aboard. But if you are giving up 25% of your daily Ah supply to a winch you are taking it from your other possibly more critical gear (navigation, auto pilot, refrigeration, lighting) and need to be on major charge at the end of the day. You could mount a couple of big photovoltaic panels and possibly make up your winch power. It doesn't make sense to me - I can hoist my main by hand to 90%, and furl the genny by hand, a powered winch is not needed. Much of that is due to careful removal of system friction and quality line replacement.
Beneteau 343 Saint Helens, Oregon OR
My 40st's are wired to my house batteries ( 4 golf cart ). I suspect my instruments and autopilot use more amp-hrs on a typical sail than the winch even though I am sailing on a river, tacking every 4 or 5 minutes. Winch only cranks for a few seconds each tack. Keep it as simple as possible.
On the other hand a separate battery could save on heavy guage wire runs if located closer to winches.
