Electric Update
10,254
For folks who are thinking about electric propulsion, check out the new Practical Sailor for a pretty good article.. The guys at http://www.propulsionmarine.com/
probably are the most advanced today in terms of a good system approach.. Still some big kinks to work out, and very expensive.. but useful for folks who use their boats consistent with this limiting aux power option..
They note a 29 mile range at 5 kts. (6 hours) on the Catalina 30 .. at 80% discharge on AGMs.. now comes the downside.. about 370 ampere hours at 48 volts (about 18 kilowatt hours) has to be replaced which would require a dedicated 10-12 hp generator to run 6-8 hours. Seems like you could drive the boat at 5 knots with that same diesel for those same 6 hours..?? Unless you can plug into a shore power outlet that can provide some pretty good current levels and don't mind sitting and charging, it doesn't seem to make sense..for anything except mild use daysailing..
Jun 6, 2006
6,990
From the crusier viewpoint it makes sense only if you can generate that kind of recharge while underway. Solar+wind+water generation will not come even close on a smaller boat. course if you had really good sail handling skills and a boat that points well and only used it in a "docking assist" mode you could reduce the AH needed substantially. course you would not be able to "get home fast on Sunday against a contrary current/wind" which is the driving schedual for most of us. that scenario alone drives the diesel solution over the electric one.
