electric panel on the 280 hunter
denise
We can not locate the electrical panel on the 280 hunter. thank you D
denise
electrical panel where is it?
WE are looking for the electrical panel on the 280.
P
Pete
look up !
Denise, I went to yachtworld.com and looked up hunter 280's for sale, the interior pictures all show the electrical panel mounted on the ceiling of the cabin just above the table. If yours is not there maybe? 120 was an option? and it is not installed on your boat. but there should be a 12 v panel somewhere(it shows in the same place on the pictures) Or else maybe I'm not understanding what you are looking for. Hope this helps!
denise
fuse box /
Thanks for the reply, but it isn't the electrical panel, but the fuse box we are looking for.... Sorry D
May 6, 2004
916
Hunter 37C Seattle
Denise I had the same question a couple
of years ago. Generally the switches on the panel are circuit breakers, just like in your house and trip/switch to "off" when shorted or overloaded. Does the same thing as a fuse but doesn't need to replaced. You may also find in-line fuses in some of the equipment wires. Is something not getting power?
Brad Baldwin
Switches act as breakers
Denise, your switches act as breakers, so there are no fuses. It might be good to have a spare switch/breaker on board in case one goes bad. Get new light bulbs and lets go sailing. Brad B
