Last Tuesday after sailing back from Apollo Beach, I turned on the engine heading toward Clearwater Pass. It started fine but after running well for five minutes it stopped seemly starved for fuel. Made it in with a tow. Spent the last week changing out filters and bleeding the lines. No joy. The engine is an old 2QM15 Yanmar. The engine always started and ran well. It seemed like it wanted to start but just could not. A friend with an equally old boat suggested an electric fuel pump. He installed one years ago and had good sucess with it. I gave it a try and what a wonderful improvement. It is so good that I recommend, if you have an older engine with the original lift pump, you consider changing it out. Yanmar is using electric lift pumps on their new engines.
I bought the electric pump from Auto Zone $37. a generic Airtex #E8012S and new fuel lines. The old fuel lines, although not leaking fuel, were way past their lifetime. I bypassed the old mechanical lift pump (cost new $200) because I did not want to worry about fuel leaking through the pump into the crankcase.
Note on fuel line bleeding: The Operations Manual is not correct. Use the steps given in the Service Manual. Link below.
http://www.rambunctiousracing.com/files/2qm15service.pdf
