Hello all,
New boat has a long run from tank to engine and was thinking about adding an electric fuel pump to assist priming system after filter changes. Engine is a Yanmar 4JH4E.
I am assuming the proper location for this would be between the fuel tank and primary filter with a switch to turn on and off. When off and engine is running using mechanical pump on engine, is fuel restricted going through electric pump? Also, any suggestions on specific pump to use?
Thanks!
Thanks!
