This is my third season with my 272LE and I finally decided to do something about the leaky joints in my water system and the taps that would never turn off completely (We had to switch the water on and off at the distribution board each time we used the faucets). After several failures I thought that perhaps the Sureflo 7.5 amp pump was too powerful. So I put a 2.5 ohm resistor on the earth side of the pump and the result was miraculous. No more leaky taps. However I find the resistor is rated 50 watts and heats up more than I like. Can any one confirm that I should be using a resistor with, say, wire of three times the present guage and three times the length? Would that give the same resistance but less heat? The resistors cost about 20.00 a shot and I do not want to get the next purchase wrong. I'd appreciate some advice on this.
