A little bit of background information. The first prompt I received was Low Voltage. The batteries were in good order. When I went to reset the breaker, then I got no power. So ordered a new breaker.
Then while sailing, we had an electrical fire. (A whole different story) Batteries were replaced as were the 60 amp fuse. Okay, problem solved? No. then I got the reading Mixer Motor Overload
I did take the Electra Scan apart and did find a little bit of foreign matter, as directed by the manual. Cleaned it, put it back together, and tried to run it again and got the same prompt. So I have several questions.
1. Did the electrical fire create a surge that may have fried the motor?
2. Do I need to take it apart again and possibly remove the motor to inspect any hidden debris?
3. Do I need to replace the motor?
