edward yontef
  • Thread starter operaed@aol.com
  • Start date
O
operaed@aol.com
i have an atomic 4 with a 3 blade r/h 12x6 prop.boat will not go backwards in reverse with any directional control.prop is turning.what do i have to do to back boat up?
Dan Tobin
Backing up
From your message I'm not sure if the boat isn't backing up at all, or if it backs up and lacks directional control. I have an O'Day 27 with an A4 and a folding prop. I wouldn't say that I have no control, but would describe the boat's handling in reverse as "sluggish". I tend to put it in reverse long enough to start moving and then pop it into neutral. The A4 provides adequate power at idle speed, so it's simply a matter of slipping it in and out of reverse as necessary. With the motor in neutral and the prop not spinning, the directional control is quite good. Good Luck!
