Edson steering
NYSail
Jan 6, 2006
3,187
Beneteau 423 Mt. Sinai, NY
On my 1986 P36-2, I have an Edson wheel. The throttle is on the starboard side with the shifter towards the stern. My throttle seems alittle tight. What type of maintenance should I do to this. I checked the main steering cable from down below and it feels in good shape....Does the shifter and throttle mechanism need lubrication inside the pedistal? Thanks Greg
Oct 15, 2004
163
Oday 34 Wauwatosa, WI
Here are a couple of links from the Edson site
that may help: http://www.edsonmarine.com/techsupport/techform.htm http://www.edsonmarine.com/faq/index.html
RAD
Jun 3, 2004
2,330
Catalina 30 Bay Shore, N.Y.
Standard cables
Greg, I helped by friend replace his throttle cable last year on a 30 Catalina and we removed it and brought it to a marine store and matched it up. Freeport Marine supply had a very large selection in stock
NYSail
Jan 6, 2006
3,187
Freeport Marine
RAD I here that place is great. Never been, however may stop in next time my travels bring me in that general area...... Thanks!! Greg
Jan 2, 2005
779
Hunter 35.5 Legend Lake Travis-Austin,TX
If your...
reverse is "down" and forward is "up" on the shift lever and your decal is worn out, missing , or unreadable, send me an address to <marcjudy@bellsouth.net> and I'll send you a new decal. I had some made and have a ton of extras.
RAD
Jun 3, 2004
2,330
Honeyman
Are these decals that go on the pedistal? My shift lever is mounted aft of the post and reverse is down and foward is up but I don't have any decals
Jan 2, 2005
779
RAD...
yes, they are usually below the binnacle and just above or next to the shift lever. Most autopilot installations obscure or cover up the decal. It's just a convienent reminder for us older folks who have had several boats with different shift patterns. E-mail me and I'll send you some out.
