This may belong into the knowledge base but leave it up to others to decide.
While taking off the top of the pedestal to install a guard (see thread: Pedestal Guard Installation) I was considering having a steering brake too.
Contacting Edson I was told it would not work with my Hunter stock installed pedestal. This seemed to be confusing since other forum users (including Crazy Dave) insured me to have installed some or have one on these pedestals.
The H260 installed pedestal is a 336 (Edson 300 series for boats from 22' to 42'). After another round of discussions with sending new pictures to Edson became it clear to me why the confusion; there are two kinds of brakes.
1. Side Brake.
If the pedestal has on the starboard side a hole with a removable plug, that's the place a side brake can be installed. The brake works via a knob, when turned it chokes the shaft of the wheel and makes it difficult for the wheel to turn.
2. Shaft Brake.
If the pedestal doesn't have that side hole, a shaft brake maybe possible to install. When removing the nut in front of the wheel you may see a hole drilled all the way through the shaft. If not, you have to buy a drilled through shaft first ($290).
As brake a rod, going through the shaft, will be installed. On front of the rod (where before the wheel nut was) is now also a knob. Turning the knob will shift the rod forward to a pin blocking the wheel from turning.
Picture 1 shows my pedestal with no hole and no plug (no side brake can be installed).
Picture 2 shows my wheel shaft, there is no drilled through only a pilot hole.
The only way in my case is to replace pedestal (for a side brake) or replacing the shaft (for a shaft brake). Since the shaft is cheaper to replace and also the shaft brake superior to the side brake is, I decided to buy a new drilled through shaft and the shaft brake.
Attachment 1 shows the side brake, attachment 2 the shaft brake.
1. Side Brake.
2. Shaft Brake.
