Edson steering cable tension adjustment.
Bob Alden
Fellow sailors, I recently had to loosen the steering cable tension during a clutch cable replacement on my h30. Since I have completed the service I've noticed an oscilation of the wheel at about 4.5 knts and above. (This oscilation wasn't present before the cable readjustment) I suspect the cable tension may be low. Has anyone had experience with this? I have an Edson system, but no specifics on cable tension or technique. Cheers, Bob Alden
180
HUNTER 25.5 St. Augustine
proper tension
It has been my understanding that the tension should be based on 1/4" play for every 1 foot of length of the cable. So, a 3 foot span of cable should have 3/4" lateral slack. Someone please correct this if I'm wrong.
Jun 4, 2004
629
Sailboat - 48N x 89W
edsonmarine.com
Edson Steering: Installation & Maintenance: edsonmarine.com/pdf/Edson_Maint_Guide.pdfhttp://www.edsonmarine.com/pdf/Edson_Maint_Guide.pdf Inspection: edsonmarine.com/pdf/steeringinsp.pdf Installation & Maintenance: http://www.edsonmarine.com/pdf/Edson_Maint_Guide.pdf Inspection: http://www.edsonmarine.com/pdf/steeringinsp.pdf
