There are two versions of Edson engine controls: the 870ST-45 and the 816ST-45. The former is the one most people are used to: the throttle and shift levers are opposite each other and operate the same way. The latter has the shift lever coming out in front of the wheel, and is moved up and down for reverse and forward.
I can use either, since I have to make a custom mounting bracket at the transmission anyway. Edson recommends the 816 since it might work better with the narrower pedestal I have. But I don't like the placement of the shift lever.
Comments? Does anyone have the 816 and can comment on how easy the shift lever is to access?
