Edson engine controls
Jim Covey
I'm not wanting to start the T vs W debate again, but IF someone was comtemplating installing the Edson wheel conversion, will their engine controls work on a Honda 9.9 4 stroke? The catalog only alludes to inboard motors like Atomics or Yanmars. I think the Honda controls are pretty pricey (yes, so are Edson's) but IF one had the Edson pedestal it appears their controls would integrate better than the Honda. So, since I want to get remote control for my Honda, I'm trying to decide if I first need to figure out about the other thing (T vs W). Thanks, Jim Covey
Ron H26.5 Fantasy
Jim, I have an Edson "Pull-Pull" wheel conversion on my H26.5. Engine controls are the stock Edson units for my pedestal with 11 ft cables hooked up to a 10hp Honda 4 stroke (1992 version) When I tilt the motor up I have to disconnect the cables at the motor so they don't get in a bind. That's as simple as lifting two levers. Other than that, they work just fine. If you can hold off until this weekend I can take pictures of the hook up and send to you. One thing I didn't think about. I have a 24" destroyer wheel which won't let me get into the lazerette without taking off the wheel. Should have went with an 18 or 20".
Jim Covey
Thanks
Ron, Thanks for the info. I would appreciate you providing some pics when you have a chance. No rush on anything as I'm not plunking any money down for a while yet. Good info on the wheel diameter, I was wondering if there would be any problems with the 24" (either too small or too big). Jim
Ted
Jim, my 25.5 has a edson w/honda 9.9 contols
The previous owner added a edson wheel with controls to my honda 9.9. He used a honda remote control kit. I just replaced both the throttle and shift cables. Got universal cables at West Marine. The whole set up works great! Looks factory. The only thing I have added was a wp5000 simrad autopilot. Ted
C
Crazy Dave Condon
Honda
The 2000 Honda changed. If you get the one with tiller, you will not be able to modify it for wheel steering. I found out the hard way and even Honda USA was left holding the bag when I questioned them. As for the remote, you can get that of course with the side box. >I am not sure if you can modify that one for the wheel steering. YOu will not be able to put any tiller on it but probably you can figure a link with the rudder post to turn it along with the rudder. Crazy sippin enough Tequila
Jim Covey
Older Honda
Thanks Dave, as always your insight is most appreciated. I think I'll be lucky because my Honda is a '95 model. Thanks for your help. Jim
