Edson compass removal
Oct 20, 2011
127
Hunter 30 Green Bay
As the title says, how do I go about removing the compass from my Edson post? I see no screws or set screws, and tried turning it, but don't want to break it..
Catalina 320 Dana Point
One commonly used is the Danforth Constellation, these have a small black plastic light fixture on top. The 2 small Phillips head screws holding the light also hold down the body shell (stainless or black crinkled paint) which lifts off to reveal the mounting.
Oct 20, 2011
127
Hunter 30 Green Bay
When I make it back up to the boat I will get a picture of it. It is an off white plastic housing that seems to rise about 5-6 inches above the metal tube of the Edson.
The 3 outer screws on the black ring of the compass, 120 degrees apart, hold it to the off-white barrel or ring. There may be some sealant from a PO as well, so you might have to gently pry the compass up. Once the compass is removed from the off-white ring, you will see there are 4 more machine screws inside that hold the off-white ring to the top of the pedestal. The compass and off-white ring would have been by Hunter - the rest is a stock Edson pedestal. Pedestal manual is online at their web site.
