Hi Bob, coincidentally, I am at the same stage as you appear to be, and am grappling with the same issue... finding an appropriate location where it's not exposed to moisture, dust, deer ticks, and is within 2 feet of both batteries, in a well ventilated space. (Just kidding about the deer ticks)! However, it would appear to be desirable to have it in a location where it is visible to allow monitoring of the indicator light. My sense of the problem after re-reading the installation instructions, is that while it may be beneficial to have the echocharger near the batteries, if you use a large enough conductor such as a #12 (suggested by Xantrex) or a #10, the line loss on a relatively short run (say 10' from panel to batteries), should work fine. That would allow for switching the Xantrex on and off. I have a secondary but related issue, that being the shore power AC Charger, a "Promariner 12" which is a 2 bank "smart charger" designed to charge both Engine start and House banks with separate direct hook ups. This would by-pass the echo charger if set up as directed. Is this a problem, or should a single positive charging lead be hooked up to the house bank only, (leaving the echo charger to take care of the engine start battery) and tape off the engine lead?
Cheers,
Barry
