removehtml]I just got done reading, and rereading, an article on pg 38 of the Feb 2008 edition of "Sail," magazine on "Easy Reefing." Try as I might, I could not figure out why one would do what this article suggests regarding reefing lines. I think the idea of threading reefing lines through cut splices in messenger lines, held in place by use of rigging tap, when you need to reef, to be pretty unhandy and maybe unworkable. Such a system could be used if one reefed at the dock prior to heading out, but I would find doing that, when it's really blowing and you need to reef now, a near impossibility.I'm not sure how my Hunter 28.5 compares to other boats, but it has a main with two reefing cringles in the leech through which I have passed two "permanent" reefing lines. I use 3/8-inch Sprectra for this purpose. When properly adjusted, a very easy task, these two lines are always ready to be used and I've never noticed any chaffing of the mainsail from them. When I do reef the main, I only use one or the other line to bring the sail down to the boom, and then I pass a stout piece of webbing through the cringle and wrap it tightly around the boom to make sure the sail stays in place. Granted, this article seems to be about racers who don't want to reef under any circumstance. The article suggests the use of small diameter messenger lines would cut down on windage and reduce chafe. I think an overweight crewperson would slow the boat down more than any size reefing line one might use. What am I missing here? Error: Error: expected [/URL], but found [/removehtml] instead[/removehtml]
