Easy bottom paint
29
Hunter 306 Jasper, Indiana
My fiberglass boat is on a freshwater lake thru the summer months then trailered to my shop for the winter. Is there an easy to apply bottom paint that will last a season or two?
Jul 8, 2004
157
- - Pinedale, WY
Needed?
John: Check with others on the lake. Out in Wyoming mountains at least, bottom paint is not needed. A little brushing might be enough in other areas. Maybe its our short summers or our colder waters? Dick
Dec 31, 2004
85
- - Guilford, CT
Multi season ablative
I use a multi season ablative. I'm in LIS, but I would use the same even if I went to the Great Lakes. WM's Multi season has held up well for me over two seasons with only light touchups between seasons.
Joe
Jun 1, 2004
8,311
Bottom Paint advisor....
Hey John, here's a link to an advisory about bottom paint that may help.
H
higgs
VC 17
VC 17 is a great freshwater paint. It is so thin that it can build up indefinately w/o the need to remove old coats. Once it is on your boat, all you need to do to put another coat on is to wipe it down w/thinner to clean it and soften it a little so the new caot adheres - no sanding! Drawback is you will have to take your hull down to fiberglass to apply it. On Lake Michigan it is pretty much the bottom paint of choice.
