only problem for me was..
Hi Mike It would be difficult to find a more accommodating and easy sailing boat than the 26, The rudder does have issues.. it will creep no matter how hard you crank the wingnut bar that compresses the rudder between 2 rubber lined plates, IF you are sailing in challenging winds OR you hit obstacles (kelp etc). This issue can be mitigated by drilling through the rudder and plates in the down position, and installing a sacrificial wood or plastic pin..I am still messing about with mine to come up with a good system using the stock components that does not rely on a sacrificial part.. (the idasailor is over 700 boat bucks)The other more ominous and scary problem I found with my rudder was the stripped bolts that held the lower rudder mount to the hull, I believe Hunter uses an aluminum backup plate glassed into the hull in this area, and the mount bolts are screwed into tapped holes, so no nuts are used inside the boat.. Problem is, as the rudder creeps the torsional stresses become tremendous and the aluminum can't take it, and although it does not outright fail, water starts to leak in around the stripped aluminum, Easy to diagnose if you have that problem..look for staining around the bolt threads where they protrude into that aft space behind the aft berth bulkhead.. An easy fix is a liberal dab of 5200, and installing nylock stainless nuts onto those threadsMore research will reveal leakage around the compression post.. (easy 5200 fix)and lots of owners modify/reduce the massive table..other than that, this is one heck of a lot of boat for a trailersailor..we love ours and live aboard for 2 months, sailing the puget sound area each summer..2 kids + a small dogafter a bit of messing about..you will be quite pleased with the Hunter 26
