I have 1988 e38. The traveler is attached to the top of the cabin by a bracket that that has four bolts on the bottom and is attached to the traveler on the top. This bracket provides precisely the necessary clearance for thr traveler to clear the companionway cover. The bracket is U shaped affair made from an L shaped piece of anodized aluminum bar stock which is welded to a flat piece of bar stock that has the four bolts in it, making the finished piece a U. Two weeks ago, sailing in some challenging conditions, the weld on the port side traveler bracket completely failed. My solution is to find a marine fabricator and have him weld it back together as I suspect this is a custom job from the builder. Does anybody know if this particular U shaped bracket was made by anyone who could sell me a replacement today?
