Dutchman Sail
16
Hunter 380 Long Beach
My Dutchman mainsail is very difficult to put the cover on. The problem is the sail flakes normally and hangs down a couple of feet on either side. Does anyone have an easy way to overcome this? I need to place 5 + sail ties in order to lift it enough to put the cover on. I know this can not be good for the sail. I also realize the sail needs to be replaced, but the $ is not there, maybe next season.
7,675
Alden 50 Sarasota, Florida
It isn't the Dutchman which causes the sail to droop. Sounds like your problem is easily solved with a larger sail cover
Dec 2, 1999
15,184
Brian:
Just live with it until you replace the sail. Then get a Stack Pack, Mack Pac or similar setup to cover your sail.
timvg
May 10, 2004
276
Hunter 40.5 Long Beach, CA
Maybe your Dutchman lines are too loose. We have it and don't see the same problem. We use a couple of sail ties to neaten things up, after dropping the sail.
Feb 10, 2007
213
Hunter Legend 40.5 Coconut Grove, FL
I agree with Tim, adjust the Dutchman lines and topping lift to get them to the right height. I normally use 2 straps and they are not really necessary..
