Fold the sytem with your sail
For the 3 years that I have had the system (on a Catalina 36), at the end of the season, I have folded it in with the sail. I have never removed it. My Dutchman system works well - I don't want to get into adjusting it from scratch.I take the main sail off, carefully keeping the Dutchman system from tangling (this is the hardest part). I lay the main sail out for folding complete with the Dutchman system as normally installed. I fold the sail in the traditional way (pulling slabs down to the foot), the Dutchman system comes with it. When you want to replace the control lines you can lay the system out and simply replace the system one line at a time with lines adjusted exactly the same as the ones you are removing.
