Dumb question
Feb 3, 2014
94
Hunter 44 aft cockpit Miami, FL
Is it okay to open your diesel deck fill and add fuel from a jerry can while you are under way and motoring? I refer not to the possibility of spills or getting seawater into the tank but is there any detriment to the engine?
Nov 6, 2006
10,152
No problem. I have done that many times .. tank should be clean otherwise you could stir up stuff that might plug a filter while engine is running and there is no "settle time" otherwise, no problem.
Dec 19, 2006
5,832
Hunter 36 Punta Gorda
Yes
I did it once entering a inlet and my gauge was bouncing around so much near
a quarter tank and did not want to motor into this inlet that I never did before and wind was around 25 knts on the nose.
I don't know what it's called but I use this hose that you shake like crazy
and fuel flows from jug into tank with out any spilling and so easy.
Nick
Super Siphon is what Nick's trying to remember. Great reviews.
