I guess in Vegas early years there may have only been one battery.
Then they added an Alternator for a house battery. So at that point
there was dual dialectical systems. You had to have a starting battery
and a house battery. You had the starter generator charging the
starting battery and the alternator charging the houses battery. You
can't cross these up in any way because the generator will burn out the
diodes in the Alternator or maybe the voltage regulator. I concidered
hooking all my batteries together to form one bank reasoning that if I
ran them all down dead I could just crank the engine. That can be done
but the generator has to be disconnected to let only the alternator
operate so that both don't output to a single battery bank. This works
fine on other boats with other engines.
The systems on my boat have been changed and the engine wiring looks
like spegetti has been thrown in there. I need to fix this mess. I
think Albin had the two systems pretty well worked out. My boat had the
batteries moved to the starboard cockpit locker. There were two master
switches installed one for the starting battery and one for the house
batteries. The original Albin wireing system was bypassed and a switch
panel installed. This was likely a good thing as we likely put more
demand on the house wireing than was originally intended and the
insulation is old now so is likely dangerouse.
I am not sure the 6 amps out put by the generator justifies two
complete electrical systems any longer. An advantage would be that any
kind of 12 volt selinoid engage the starter and no other electricals
would be needed for the generator.
Power for the house system could be taken directly through the
battery switch directly from the batteries. Power for engine would come
through the starting main switch then going through the ignition switch.
This May not work as they both have to be on so as to not burn out the
alternator diode. ( In case anyone is wondering I am just thinking out
loud with this post. ) The two switches on the starting system may not
be a good idea if there is no separate charging starting battery.
Because it is so easy to be at the dock and start the engine with
a battery charger on it is easy to burn up the alternator circuit. My
first inclination was to never charge the starting battery with a
battery charger and use only the starter generator to charge it thus
eliminate the possibility of running the engine with a charger on. I
guess a solution would be to have the ignition switch automatic shut off
the battery charger. This was using the two seperate systems as designed.
After all this thinking what I think I will do is start over. I
will disconnect all the engine wireing. Then hook up the starer/
generator and its sellinoid as was oriinally done with power coming
through ignition switch. If this works and charges I will know the
selinoid is OK. Then I will hook up the alternator so that I can check
it's output and that it is charging batteries. I will have to be sure
that the generator and alternator cannot both charge both battery sets
so as to inter-fear with each other. I guess if I want to charge the
starting battery I will have to be sure the starting battery main switch
is turned off so the engine cannot be started. Be nice if it had a
lockout on it for safty sake. Still the same is true of the house
battery. I would like this all to be fail-safe. I am thinking that the
alternator has to have exciter current to operator so if that is not
turned on it can't try to put out current and burn out it's diaode.
I du id not intend to post this but then somebody may have a a good
solution to this or just maybe learn something from the execise. I have
learned a few things and hope it helps someone else.
I think I will go to a single charging system using only the
alternator as that is likely the last complicated and so maybe the most
dependable.
In any case input would surely be welcome as I am likely in over my
head.
Doug
dependable.
head.
