My last post re gearbox drama prompts me to start a new subject, lot of good advise and just the moral support when all is looking grim. So, here we go, tested my Perkins 6.354 wet exhaust manifold today........ failed badly, anodes are non existent anywhere on motor, previous owner watched too many sunsets and not much else. Anyhow well under way with re building motor on board ( a diabolical task), am wondering, can you use a standard diesel manifold and bypass raw water from heat exchanger directly into exhaust downstream from manifold ? Reason being, replacement manifold is $1600 and another failure equates to another seized engine.. not a good look. Is this workable? Keen to hear your input
