Normal
It is the nature of the packing material not the age of the vessel. With standard impregnated packing flax, the compression on the stuffing box should be adjusted to permit 1-2 drops of water per minute with the shaft stopped. At this rate the water should evaporate before it gets to the bilge when the engine isn't running. When the shaft is turning this rate will increase and you will accumulate some bilgewater.After the shaft has turned a lot, the rate will continue to increase, requiring further adjustment. As the material ages under comression, this occurs with increasing frequency until it needs replacement. This task can be none in the water. The box should never be so tight that it stops the water flow since water is the lubricant that reduces heat from friction and wear on the shaft. The test is that after a few minutes of running, the stuffing box should be a little warm but not so hot that you can't hold your hand on it (while the shaft is stopped!!!!)Gortex packing is available at a very reasonable price and can be adjusted so that there is no drip at rest and very little under power. It doesn't heat up and it doesn't compress as easily requiring far less adjustment and rare replacement. You should be able to maintain a perfectly dry bilge.PSS makes a drip-less seal that requires a haul out to install and runs a couple of hundred dollars. It has a few idiosyncrasies to observe, but has a superb track record. I've never heard of a documented catastrophic failure of one of these seals, but, in theory, if it occurred it could sink your boat.
