Dropping rudder yamaha 33
Jun 11, 2016
9
Yamaha 33, tall rig Victoria, BC
Anyone here try to drop the rudder on a yamaha 33? If so id like to know what your experience was with it. Did you notice any weaknesses or damage when you did it?
I plan to use it as an offshore boat but im curious to know if the rudder is strong enough.
Nov 30, 2005
2
- - Adelaide
Rudder removal is easy (tiller). Remove the plastic block on the front of the rudder just below the bottom bracket. 2 screws but hidden under sealant. Support the rudder, remove the tiller and top clamp then remove the screws that hold the bottom bearing. The rudder will be fairly heavy as it is likely full of water. The rudder stock is very strong. Overdesigned by comparison to other similar sized yachts. I cannot stop my rudder filling with water so I just live with that. The lower bearing in the hull is bronze and though it doesn't wear is a little sloppy. The bottom bearing is just a stainless tube that fits inside the rudder stock. This can be a loose fit and allow for a bit of lateral movement but if you fit a fibre bearing inside it you can remove all slop from the bearings. The rudder is very strong and certainly capable of off shore sailing. As I said they do fill with water and the foam inside gets water logged. I cut mine open and replaced the foam then reglassed the whole rudder (under the boot top line) with rovings and epoxy. Tried everything to seal the rudder but find it still fills up with water probably from the joint between the fibreglass and rudder stock. Hope this has been of some help.
Aug 27, 2025
1
Yamaha Yamaha 33 Monterey
A decade+ later I find your post XD
My yard is working on this same issue for my Y33 at the moment.. Most importantly re-fabricating the electrolysis corroded bottom bracket, but also the deskinning/refoaming job too. If you see this, I have to assume you used closed cell foam right? Not the end of the world if it waterlogs again I guess.. but I'll try to be optimistic till I haul out :)
Here's what it looks like internally
51
Yamaha 30 - Tall Rig Vancouver
I don't have experience with a Y33. And it's a different rudder system than my Y30. On my Y30, the rudder needs to be able to float so that it doesn't put weight on the top bearing (that is screwed into the outside stern combing). As said, the 33 is a different rudder system, but might be worth confirming whether the rudder needs to be able to float.
