A-frame info please
Charlie - I've been thinking about using an A-frame for raising/lowering the mast on my O'Day 27 , which must be more or less the same weight/length as your 272. The smaller boats may be able to get away with using a gin pole, but I thought the A-frame would give more lateral stability for a c. 33 ft mast. If I understand correctly, you can lower the mast without releasing the shrouds ? I would have thought that at least the fore lowers would have to be let go. Can you provide a little more detail as to the length of the A-frame, where it is pivoted (made fast to the deck or ?) Does the A-frame give enough stability to raise/lower the mast when the boat is afloat ?Thanks
