Thanks again Robert
I thought that it would be alright. I didn't want to put too much tension on because the deck would just be under that much more strain, even though I used the big backing plates. I only daysail on an inland lake and I'm pretty conservative when it comes to reducing the sails. I've found out that the boat sails faster and is way easier to maintain headway than if I was constantly heeling and rounding up when overpowered. CharlieCobra, sorry for carrying on a seperate conversation inside your thread. Last year, a Seward 23 lost his mast while in the slip opposite of mine. He did not have any sails bent on. My daughter and I had to pull the mast up out of the water and we used towels as padding and lashed it to the bow and stern rails with short pieces of line we had on our boat. The boom was not there, and we thought that it was on the bottom, but luckily, the owner had it iside of the cabin. I looked the riging over, and found that the turnbuckles all were without cotterpins. The turnbuckle for the forestay had worked itself apart, causing the failure, and all parts were still there. I gave the guy a bag of cotter pins when I next saw him, but he never installed them! Make sure that your turnbuckles are pinned.Later in the year, a Catalina 22 in another nearby slip had the cockpit filled with water all the way up to the hatchway step, and water was getting into the cabin. I used a 5 gallon bucket to bail some of the water, and my bilge pump as a pressure source to force the clog out of the cockpit drains. I just held the discharge hose against drain while my buddy pumped the handle. Once unclogged, the rest of the water in the cockpit drained. I used that technique another time on my father-in-laws drains with equally good results.
