Thanks for sharing that.
I would like to relate a story of my own for comment. I have been sailing on Colorado mountain lakes for many years and surprise squall lines are an ugly reality. "Reef early, reef often" is obvious good advice, but taken to its limit means you will never keep your sails up if clouds are developing. I have been overtaken by similar 0-50+ winds in less than two minutes with little to no warning. Scary...you do what you can...sounds like you kept your head and your boat.
This story, however, relates to South Florida where I am a beginner at weather. In mid June we were sailing back from Bimini on a typical hot afternoon. Winds SSE 10-15, steady...a perfect day. WX radio talked all day about 'possible thunderstorms, locally heavy' and so on. This had been the prevailing weather for days. About an hour before sunset we could see a line of thunderstorms building all along the coast, as they had done most afternoon for many days. We had main and 125% genoa up and were making 5 kph on a course for North Miami about three miles off of Miami Beach.
One of the thunderheads seemed to be bigger and faster growing than usual and so we decided to begin furling the genny. Within two minutes the skies went from blue and sunny to completely overcast and the water turned an ugly color mix of dark green and almost black. We had the genny in the motor started and were starting to reef in the main. The WX radio switched from its all day forecast to 'locally heavy thunderstorms and we can not rule out the possibility of 60 mph winds.' That was an unusual broadcast to my ears and so we pulled in the entire main.
Visibility dropped to less than the boat length and a brutal wind dead out of the southwest hit us with a violence I can not describe. The boat heeled 25* and held there even though there was no cloth up whatsoever. I held her bow dead into the wind for a while but she just could not sustain that course into the wind. My compass showed a heading of 180 while my Lowrance COG showed me making 5 knots on a heading of 0. We were backing up....fast We were about 3 miles off of Hallendale Beach when it hit and in 100+ ft of water so grounding was not an immediate fear. All we had to do was maintain that heading and wait for it to pass, which I think that they usually do in a matter of minutes.
This fierce, intense wind burst would last for 25-30 very long minutes. Eventually the waves (which had had only a couple of miles to build as this wind was offshore) began to beat the bow badly and force her out of the upwind course. It was an odd thing. Six to eight foot waves are not unusual, but the chord length was so short on these that soon (I estimate 12-15 minutes into this ordeal) the bow was forced across, and then down, the wind. That was truly scary and with no chance whatsoever of regaining the upwind course (the 13hp Yanmar is a trooper but could not generate anywhere near enough power to turn the boat against that wind.) I put her on a downwind course and decided to try to run it out. My Lowrance showed speeds over ground of 10, then 11 and peaked at 12.5 knots! The rain was like being shot with salt from a shotgun. The sea looked like a ground blizzard in Wyoming. My max sailing speed is around 6, and the thought that a thunderstorm can move the ocean herself at a rate of several knots is very humbling.
After about 10 more minutes it eased and we could regain control and heading. We had been pushed north over three miles in about 30 minutes, much of that time on a southerly heading. Most of the downwind time the sea was following so close that the rudder was useless. I actually thought at one point the cable must have snapped because the wheel floated so freely and with so little effect. I learned that even on a placid day in sub tropical seas that thunderstorms can come out of almost nowhere with an intensity that can startle. Fortunately we had all the cloth in (except the Bimini, which is bruised but reparable) and the boards in. That was no small part luck.
Question. With a stacking up following sea and an incredible following wind would the best course to (try to) hold be straight down or 20* off?
