Lately my boat's engine began hunting : at 800 rpm the motor goes up and down. if I increase the rpm to 2000.it is less significant.First i
I tought a bad shaft aligment was the reason so I disconnect the 2 coupling between the shaft and the transmition and I can raise the rpm to 2800 easily but as soon as i put some charge on the engine, it will begin to go up and down again. Why does this hunting thing happens with some charge and nothing's wrong when in neutral ? is this an alignment issue or fuel adjustment issue ? If my alignment was that bad, could it make the shaft turn slower. I just motored 35 hrs last week and everything was o.k.
tanks
tanks
