Strange Sounds, But No Leaks
Joe,I put the seal on in June. So far, no leaks. The bilge stayed dry for a couple of weeks. I noticed some water after the rain we had a week or so ago. I must have a leak somewhere else. I am trying to get the boat dry and keep it that way so it won't smell musty. We went to Petaluma a couple of weeks ago and when we got back I noticed a big black stripe all the way around the interior of the hull and under the aft berth plywood. I don't know if that was related to a normal break-in since that was the first sustained operation after bringing the boat back from Svendsen's. The other thing that is weird are the sounds we now get. I don't know if there are now some new resonances since the shaft is only supported at the cutlass bearing and the engine coupling as opposed to being held captive by the old stuffing box, but it sounds different. Certain RPMs are the most pronounced. At times it is very quiet and other times (like when turning the boat to starboard) there is all kinds of noise. I checked the TIR on the shaft and it is around 0.003". It is not rubbing on the stern tube as far as I can tell and it is well aligned in the strut. Check the previous posts under my name an you will see a rather detailed description of how my wife and I realigned the strut after changing the old cutlass bearing. I also added the Drive Saver. It is a flexible spacer that is added between the flanges of the coupling. It pushes the prop back about an inch. I did not cut the shaft off to compensate. I hope that extra inch that the prop is now back from the strut isn't causing any undue flexinng of the shaft. I haven't tried running with the new seal and no Drive Saver.Overall, I am happy with the dripless seal. It appears to be operating as advertised. I just need to resolve or accept the noise factor. It was pretty easy to install. If you are going to do it yourself, start soaking the coupling with a penetrant as that is the hardest part to remove. Since we are next door marina neighbors, you are welcome to come over and check it out. We can take it out for a spin.Regards,Allan"Alchemie" H34Alameda (OYC)
