While following the conversation on another thread the subject of proper venting for a dripless shaft seal came up. Which made me think since I have a dripless seal and didn't remember ever seeing a vent hose. I went down to visit the boat yesterday and made a point to look at the setup there. Sure enough there is no vent coming off my seal. I'm guessing it is an old design before they added the vent. Checking the records that came with the boat I see the seal was added in '95 along with a new shaft and cutlass bearing.
Which brings me to the question of what maintenance and/or life expectancy is there for this part. Since it is a primary barrier to keep water out of my boat I don't want to take chances. It looks OK but 20 year old rubber scares me. PSS says to replace the bellows every 6 years so that needs to go to the top of the list for next time she comes out. But what about the mating surfaces, are they good forever? I also wonder why the current design has the vent? Is there a reason I should have the new, improved design? I remember the surveyor looked at it and explained you just needed to remember to burp the air out after a pullout. But after going through all the work to pull the shaft to replace the bellows you gotta be thinking, might as well replace the whole damn thing....
