Anyone have any experience/comments about that clay-like material that molds to the inside of the stuffng box to create a shaft seal? Pretty pricey stuff (@$64 from Defender), but wonder if it may be worth it? Better than GTU packing?
Warren ............... in my experience, I believe the same drip free, dripless, or whatever you want to call it (I call it bone dry) packing can be had from at least teflon impregnated flax all the way up to high tech GTU packings and better.Pretty pricey stuff (@$64 from Defender), but wonder if it may be worth it? Better than GTU packing?
So ......................... how are my royalties coming on that ? Any hope of early retirement :cry: ?I've added it to the Stuffing Box article I wrote and use to link whenever this subject comes up (like weekly).
................... as the packing I've mentioned is teflon impregnated flax, and not the expensive green doughy material. Haven't had any experience with that material but I wouldn't doubt that it'll work just as well or better (bone dry). Just a little too expensive for my blood.I will use the green Teflon, again.
Four or five rings? Why so many? I've never put in more than 3 in any of the stuffing boxes I've had. (3 different boats.) So long as you reduce or mitigate the water flow while still keeping the stuffing box cool, that's all you are after.The last two shaft assemblies that I have rebuilt have been one inch. On the first one, as per "instructions" that I must have ascertained from a seance or something, said 3/16". Not a chance in hell. By the time I shoved 4, maybe five rings in it, I nixed that train wreck. So, 1/4" teflon is the ticket.
I'm very, very far from an expert on this or anything else related to sail boats. However, I've changed my packing two or three times and always did it when the boat was in the water. The first time, the packing was so hard it took me an hour or more to get it all out. Meanwhile, the water was coming in, but once I realized that my bilge pump could keep up with the inflow, I relaxed and did the job.Ralph,
Thank you for your research. I have used the same material and had a dry bilge. I was told that the shaft will be scored over time and the boat yard replaced it with traditional flax packing. Now it leaks constantly. On the next haul out, I will use the green Teflon, again.
I suspect that is his point - the 3/16" was too small, which he figured out after the 4th or 5th ring not being sufficient. Moving up a size, to the 1/4", resulted in a properly stuffed box with fewer rings.Four or five rings? Why so many? I've never put in more than 3 in any of the stuffing boxes I've had. (3 different boats.) So long as you reduce or mitigate the water flow while still keeping the stuffing box cool, that's all you are after.
If the packing is properly sized it should be snug but not inordinately difficult to insert. On my previous boat, a Catalina 30, I replaced the stuffing box as part of a prop shaft replacement. The shaft was 1". The previous box used 3/16" while the new box used 1/4". It all depends on the specific box. My current Ericson 26, with a little Yanmar 1GM, has only a 3/4" shaft and has a baby stuffing box that takes 1/8" packing! Prior to my buying this boat some genius mechanic managed to jam 3/16" packing in there and it created all kinds of problems before I removed it and put in the properly sized stuff.
All forms of packing--whether Goretex, Teflon, or conventional flax--require some flow of water to cool the shaft while rotating. A slight weep may be adequate for this, though several drips a minute are fine as well. It should not be bone dry while the shaft is in rotation or the box will overheat. The "sweet spot" would be a slight drip while running with the dripping stopped with the shaft at rest.
Nom,I suspect that is his point - the 3/16" was too small, which he figured out after the 4th or 5th ring not being sufficient. Moving up a size, to the 1/4", resulted in a properly stuffed box with fewer rings.![]()
................. as shown by the temperature on this running, bone dry stuffing box.All forms of packing--whether Goretex, Teflon, or conventional flax--require some flow of water to cool the shaft while rotating. A slight weep may be adequate for this, though several drips a minute are fine as well. It should not be bone dry while the shaft is in rotation or the box will overheat. The "sweet spot" would be a slight drip while running with the dripping stopped with the shaft at rest.
