Drilling rudder to drain water before freeze up
RBilly
Jun 18, 2014
28
Oday 28 Midland
I have an '83 O' Day 28 on Georgian Bay , Ontario, Canada.
Just had a survey done and showed higher levels of moisture in rudder. All older sailboats do!
There is no cracking, splitting on top of rudder, edges or bottom.
We're just starting to get into freezing temps here and want to drill a hole /holes to allow to drain out before Winter and also Spring.
Any suggestions on where, how big, deep and how many? Of course I would seal up again with epoxy before antifouling and launching in Spring.
Thanks,
RBilly
May 25, 2012
4,338
on my 66' alden i installed a bronze drain plug in the bottom of the rudder. i open the drain when i hall the boat out for the winter season each year. this year i saw about 1/4 of a shot glass come out. i just figured it would keep the rudder drier this way year to year. do not have to reglass each spring. easy peezy
If you let it freeze, you'll know exactly where the water is. ;)
But you're trying to avoid that.
The rudder probably built in 2 pieces and foam filled. If it is a closed cell foam the water will work its way down to the bottom the rudder. A ¼" hole through the skin of the rudder at the lowest level will let most if not all of the water to drain.
The usual place water will get into the rudder is at the rudder post. The SS post and the fiberglass rudder have different rates of expansion, this will allow a small opening to form around the rudder post. Once your rudder is dry, drop it and clean out that joint and seal with a sealant that has good adhesion and good flexibility. A polysulfide caulk, like Life Caulk or a caulk like 3M 4200 or 4000. Do not use 5200! 5200 is an adhesive, not a caulk that is flexible.
BoatWorks Today has a video series on repairing a wet rudder core. Here's the first video
Good luck.
Likes: rgranger
Sep 20, 2014
1,330
Rob Legg RL24 Chain O'Lakes
Drill a hole you can put a small stainless screw back into. Then it makes it easy to drain the next time.
Gunni
Mar 16, 2010
5,937
Tape up a PVC plumbing fitting over the hole that will accept your shop vac hose and let it run for 20 minutes or so, then leave the rudder open to drain. You can do the reverse in the spring and use soapy water to see where the rudder leaks. Usually at the rudder post, rudders bend and flex against the post.
Jun 3, 2004
890
Hunter 34 Toronto, Ontario Canada
I drilled 2X1/4 holes in the bottom of my rudder after I bought the boat in 2002 and fixed the bulge in it- probably caused by freezing water in it. I drilled up about 3". I fill them with about 1/2 inch of caulk- used 4200, silicone. outdoor caulk- what ever I have had handy. At haulout I pull the caulk out and let the water drip out . It usually looks like there is less that 1 cup of water that comes out. I have cleaned and caulked the top of the rudder at the shaft joint, but a bit stll seeps in even after refinishing the rudder 5 years ago and applying 5 coats of epoxy.
JRacer
Aug 9, 2011
1,393
I drill a 1/8 (or so) hole in mine straight up from the bottom at the lowest point and leave it open all winter to drain and dry. Then, in the spring, I epoxy the hole closed. Always put a piece of blue tape on the side of the rudder to remind me to fill the hole before launch ("remove before flight").
NYSail
Jan 6, 2006
3,178
Beneteau 423 Mt. Sinai, NY
On my first boat a 1977 cal 34-111 I dropped the rudder every winter and put it upside down next to the boiler. It was an easy drop....
Greg
Oct 6, 2007
1,172
Hunter H30 1982 Chicago IL
I have been drilling a small drain hole at the lowest point on the bottom of the rudder and a smaller air hole near the top, then filling them with thickened epoxy in the spring. I think the air hole at the top helps drain the rudder more quickly and more thoroughly.
I keep spring and fall checklists in the Notes App on my iPhone and iPad for easy reference at the boat yard so I don’t forget to fill the holes in the spring.
