Drilling/cutting
495
In search of my next boat Palm Harbor, FL
I want to install a 12v cigarette type outlet. To do so, I need to drill, or cut, a 1" diameter hole in the fiberglass. What is the best tools for this? I have a couple different size wood core "bits" used for putting holes in doors that are small enough, and a couple hole bits for ceramic, and a couple chisel type bits.
What do I use?
Sep 28, 2008
922
Canadian Sailcraft CS27 Victoria B.C.
I use a forstner bit of the correct size. Start slowly in reverse to eliminate chipping, then switch to forward.
544
Bristol 43.3 Perth Amboy
Options
1 inch hole saw will do it but a forstner bit will do it cleaner. They are more expensive.
Ross
Jun 15, 2004
14,693
Re: Options
You will ruin a forstner bit on fiberglass.
Sep 15, 2009
6,244
S2 9.2a Fairhope Al
Ross is absolutly correct...use a hole saw and run it in reverse to start with then run it foward to finish the hole no need to rush the work and you will have a much better job in the long run.....
regards
woody
Mar 6, 2008
1,525
If you use a hole cutter - first test the actual size of the hole by cutting a hole in a plywood. Hole cutters sometimes makes a hole that is slightly larger that the listed diameter.
Sep 28, 2008
922
While fiberglass isn't the best for a forstner, or any blade for that matter, mine have been doing well over the last year. I used a 12mm for the holes for toggle switches (Blue Seas 4150) and the larger for 12 volt sockets (Blue Seas 1011), and after many holes in both fiberglass and wood with each I have not noticed any problems yet. Even though it may limit their life it still is only pennies per hole. That is what I bought them for.
Dremel multi tool blades have the shortest life of any blade or cutting tool I use - and they cost more than the forstner - but are invaluable for cutting square holes for panels and instruments.
Ross
Jun 15, 2004
14,693
You will know immediately what you have done to that bit when you decide to drill some wood. My forstner bits run double digit dollars each so I take very good care of them. There are some now that are make with replacable carbide blades and I haven't tried those.
BarryL
May 21, 2004
1,127
Hey,
I would use a hole saw. I would also put duct tape on the surface before you drill. Lastly, I would cover the floor because you're going to great a LOT of dust.
Barry
Waddie
Oct 16, 2011
2
O'Day Mariner 20' Kansas City
diamond hole saw
I do most of my grinding on fiberglass with a 9" diamond faced grinding wheel. I buy them at Harbor Freight - $49.00 but often a half price - they grind FAST and are long lasting. (this summer I gutted a 20' sailboat, leaving only a nice hull)
I say this because Lowes has a diamond edged hole saw (in any size) that cuts fiberglass like butter and clean, too. It also lasts a long time.
But it may cut holes a little big, I don't know.
Have fun,
regards,
Waddie
Jul 18, 2009
274
marine clipper 21 ft santa ana Southern Lakes,Yukon
Re: diamond hole saw
spade bits do the trick and they are cheap cheap cheap..
